Total posts in this thread: 4
Previous Thread This topic has been viewed 1073 times and has 3 replies Next Thread
test999
United Kingdom
How to remove curves that indicate which way the door swings?
Is there a way to remove a curve that indicates which way the door opens? thank you
[Jun 25, 2024, 10:36:20 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Daniels118
Italy
Re: How to remove curves that indicate which way the door swings?
Yes, the easier method is to export the door and import it as a new door.
[Jun 25, 2024, 4:50:56 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Definitely the easiest and quickest way.
For a beginner here's why:
The sashes (the curves that indicate which way a door or window opens) are defined in a Furniture Library as additional properties for a model. By exporting and importing you get the same door but without the additional properties from the Furniture library.
Note that if more extra properties were defined for the door you will loose those too. For example a distance indication from the wall to extend a border outside the wall, a custom cutout shape, or the default elevation.
[Jun 25, 2024, 6:02:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
AaronRogers
United states
Thanks, I will try it and if I face any issue, I will ask by starting my own thread.
[Jul 12, 2024, 9:35:55 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
