South Africa
Export plan to image plugin creating empty png
I am on version 7.4.1 of Sweet Home on a Mac M1, and have installed ver 1.0.2 of the Export Plan to Image plugin ExportPlanImage-1.0.2.sh3p.
When used, the plugin creates a zero byte png file in the destination folder (/Users/m1/Library/Containers/com.eteks.sweethome3d.SweetHome3D/Data) and a .tmp file in the /Data/tmp folder.
Manually changing the tmp file extension to .png results in a fully functional image.
Re: Export plan to image plugin creating empty png
I tried again ExportPlanImage-1.0.2.sh3p plug-in with Sweet Home 3D 7.4.1 on a MacBook Air M1 and I didn't encounter any issue. Did you get any error message? How large is the exported file found in tmp folder?
South Africa
No error message. I typically export at 2000px and the file in the tmp folder is around 400kb.
In case its relevant I'm on Sonoma 14.5, and have the following plugins installed: - Change color - Export plan to Image Multiplier Pan in 3d view Plan rotator Plugins manager SVG tuner Staircase generator Wirings de.starrunner.sweethome
I just ran into this bug on a fairly large image. Reducing the image size from 10,000 pix down to under 9,000 fixed it in my case, although for some reason the .png files save with black backgrounds when opened, plain in the preview, doesn't happen all the time, and only with png not jpg
