Re: 2D display of items still not working properly
In the 2Dview items are stacked according to their elevation. That's why your item 1 shows on top of item 2 in the 2Dview. Like Waldemar said, grouping can solve that. In a group the order of the items determines which is shown on top. If you want a specific item in a group to be on top then there's a little trick to do this: select the item in the group and cut it. Select the group and right click, select 'Paste to group' from the context menu. Now the item is the last item in the group and should show on top. Knowing this you can create a group in the order you want by selecting the items in that order before grouping, last one selected is the one on top.
Dodecagon.nl 1300+ 3D models, manuals, and projects
[Aug 17, 2024, 9:28:22 PM]
[Link]
