Total posts in this thread: 5
Previous Thread This topic has been viewed 932 times and has 4 replies Next Thread
vanheerde
Nederland
Colors and texture change after 3D picture
Hello!
I made an image. When I take a 3D photo, the colors and textures of objects in the image change. Does anyone know how to solve this? I've included images in the attachment so you can see what's happening.
https://www.dropbox.com/scl/fo/6udgbobru6zj7z...zq0oizmw3dgqk3di&dl=0
Hope to hear some solutions! smile
Tim Vh
smarthome-specialist.com
[Aug 23, 2024, 11:55:08 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Colors and texture change after 3D picture
To make a "natural" looking picture, you have to add lightning. Easy said, not so easy to do. Read and look at some posts from GaudiGalopin3324 to see how he makes stunning pictures.
[Aug 24, 2024, 11:18:35 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Better make that lighting. Lightning is so destructive wink
Sorry Hans, I couldn't resist ;)
[Aug 24, 2024, 11:39:05 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sjb007
Status: Online
If you want the image to look like the "correct version" you need to turn the "Kwaliteit" down. That gives you renderings that look like the 3D viewport rendering.
If you just want to make your "bad picture" brighter but keep the more natural rendering then you could start by moving the time and date to a time when the sun higher in the sky. At 8:00 am the sun is still low, hence the lower light. Put it to noon, and change the date to 21 June (Summer Solstice) and the sun will be as high as possible overhead, and it will give a much brighter result.
[Aug 24, 2024, 2:58:51 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sjb007
Status: Online
Doh! I now see the actual issue. You have corruption in your bad rendering. Like the rug where half the texture disappears and becomes flat grey. OK, that is strange. It kind of looks like Z-fighting, but I've not seen Z-fighting in the rendering before, and you shouldn't see Z-fighting within a model like the TV, or the slat panel on the wall.
Another possibility (and my best guess) is that your models have flipped normals for some of the geometry. This often happens with lower quality free models. The 3D view is "ignoring" the flipped normal, rendering the texture on both sides of the triangle. The Yafaray renderer is not putting the texture on both sides of the triangle, so any flipped normal is shown a base colour, and untextured. You would need to fix the models in a suitable modelling application if this is the case.
[Aug 24, 2024, 3:20:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
