Total posts in this thread: 4
Previous Thread This topic has been viewed 2129 times and has 3 replies Next Thread
leonidas187
Türkiye
Rendering
Friends, can we install rendering engines other than yafaray and sunflow in sh3d? If we can download it, where and how can we do it?
[Sep 23, 2024, 4:07:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
sjb007
Re: Rendering
Nope. Another renderer requires export/import to another application, unless someone tackles the significant job of adding another renderer to SH3D.
[Sep 23, 2024, 9:54:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Status: Online
Re: Rendering
I looked into this and like sjb007 says it's a significant job. I stopped looking into options when it was clear that it wasn't going to be much use anyway because Sweet Home 3D only supports a limited set of material properties. For example, you can only have a single texture mapping (map_Kd) but none of the other mappings.
If you really need a special rendering export it to Blender and in Blender add all the extra material properties and texture mappings. Then render with one of the renderers supported by Blender.
The only thing that would justify another renderer in Sweet Home 3D is one that uses the GPU instead of the CPU that both current renderers use.
[Sep 23, 2024, 10:03:11 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
leonidas187
Türkiye
Re: Rendering
Thank you both very much.
[Sep 24, 2024, 1:33:32 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
