Thread Type: Sticky Thread
Previous Thread This topic has been viewed 90755 times and has 2 replies Next Thread
edgeeven
Dev environment setup
Hi , i'm trying to figure out how to build the project and set it up in my Intellij IDEs in order to customize some components, i would highly appreciate if someone points me to the right direction
[Oct 25, 2024, 9:05:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
Re: Dev environment setup
My opinion: use this recommendations for plugins (I use the basic Eclipse IDE).
For Intellij IDEs and for the main program you will have to try your self.
When you will find-out howto, please let us know and share the procedure.
Thanks in advance!
[Nov 1, 2024, 10:52:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
igbanam
Ghana
applause Re: Dev environment setup
I managed to build the project by downloading the source code and running the build command.
1. Clone the repository
2. Inside the SweetHome3D folder, run `ant`
You must have the `ant` build tool installed. Homebrew has this.
brew install ant
You can take a look into the "build.xml" files to see how the tool is built.
There are ".project" files which instruct your IDE on how to setup the project. I develop in Vim, so my case is a bit different. But ".project" gets you enough mileage.
[Apr 24, 2025, 4:31:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
