Total posts in this thread: 2
Previous Thread This topic has been viewed 5719 times and has 1 reply Next Thread
Brian4C
Elevation Issue
I just went back to a file I haven't touched in months. I am trying to add a garage door but when I do it inserts about 3 feet above the ground. The issue is that Sweet Home says it has an elevation of zero. I tried copying an existing door and when I paste it, it inserts with the same issue; floating a few feet high but registering an elevation of 0. Any idea what is causing this?
[Dec 29, 2024, 9:34:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Elevation Issue
Did you draw a floor for your garage?
Check the elevation of your level (double click the level tab if you have multiple levels). You might have a level below your 0 level and no floor drawn. In such a case the floor thickness will show as empty space although 3 feet would be a very thick floor.
[Jan 7, 2025, 3:54:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
