Previous Thread This topic has been viewed 2307 times and has 2 replies Next Thread
Gateway01
Photo rendering does nothing
I'm using SweetHome3d v7.5, photo rendering 2.3
When I try to render at level 3 or above using either renderer the timebar just flashes and then does nothing. With a different model using the same setup it works fine.
Any ideas where I should start looking please?
[Jan 11, 2025, 1:27:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Photo rendering does nothing
If it's a large model - increase mmeory (Xmx trick - see FAQ)
If it's a faulty model
- delete half of your models - try
- if it works - undo - keep halving, until you have the faulty model
[Jan 13, 2025, 11:04:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Gateway01
I've subsequently found that it does work if I use the toolbar icon but not if I use the menu.
[Jan 13, 2025, 12:22:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
