Italy
Re: Problem with saved camera position and zoom!
I know this may sound absurd, but I can assure that Pan3dView plugin doesn't affect the model anyway, the best chance is that you have moved the lights on the floor by mistake. Please check that the lights are at the proper elevation. If you don't feel confident with the elevation field, you may also try the View light sources plugin.
BTW the first problem you reported is weird, I have no problem with Pan3dView and stored camera positions. Are you using the latest version of SH3D and Pan3dView? Is SH3D the installer version or one from the stores? On which platform? If you want to spend some time helping me to improve the plugin, please try to reproduce the problem while collecting the logs as described here: https://www.sweethome3d.com/support/forum/viewthread_thread,9906#46443 and post the content of the log file here. If you can't get the logs with the above method, you can try this one: https://www.sweethome3d.com/support/forum/vie...read,5072_offset,30#53691
Croatia
From my own experience, I avoid any plugins to perform some actions. As far as I know, SH3D is an open source program and so are the plugins written for it. Far more advanced and terribly expensive 3D programs also have their own plugins that can cause problems. I think that's why it's better to use the capabilities of the program itself without adding plugins, because every hardware configuration is different and there will always be situations when it won't work well.
True, but most plugins for Sweet Home 3D add features that are not available in the base program. It's either do without or use the plugin. I use multiple plugins and have encountered very few problems with them.
