Total posts in this thread: 8
Previous Thread This topic has been viewed 211 times and has 7 replies Next Thread
John37
United Kingdom
Polyline - how to delete a point, version 7.6
Polyline - how to delete a point in version 7.6?
I can't find a menu or anything to do this.
AI says there is a modify menu, but I don't have one.
Double-clicking opens a Modify polylines dialog but there is no item to show or delete points.
What can one do please?
[Jul 17, 2025, 10:00:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Polyline - how to delete a point, version 7.6
Version 7.6? I assume a typo, the lastest version is 7.5.
Unfortunately you can't delete a point from a polyline. You will have to draw a new line or leave the point in the middle of a straight line.
Don't depend on what an AI says, they are very unreliable for finding answers and often plainly wrong. For example this question about removing a point. You can add and remove points on a room and the AI focusses on "remove point" and doesn't take into account that a polyline is not the same as a room.
Search this forum and you will have a much better chance of finding a correct answer.
[Jul 18, 2025, 7:33:08 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
John37
United Kingdom
Thanks Keet, very helpful - I can stop looking!
Yes, I take your point about AI, that's why I posted in the forum.
Do you think a feature to add and remove points in polylines could be implemented? Even just remove a point if it's difficult to implement add as well.
Btw my About screen does say it's version 7.6. It may be wrong of course....
[Jul 18, 2025, 8:05:29 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Check this thread. Perhaps you should replace your wrong version with the latest 7.5 from the download page.
[Jul 18, 2025, 8:17:40 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
1. Install Advanced Editing plugin;
2. Draw a polyline;
3. Menu: Plan -> Edit points... (or the icon from top-right).
You could add, delete or set a precise position of selected point.
Could be also used for rooms.
[Jul 18, 2025, 11:30:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
2. Draw a polyline;
Aaaarrgh, I totally forgot about that little gem since I rarely use polylines. It should be available in the contect menu of a polyline, not hidden away in the plan menu.
But anyway, @John37, you CAN edit the points following what dorin wrote.
[Jul 18, 2025, 12:06:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
dorin
Romania
It should be available in the context menu of a polyline....
...and a room also BUT
I've tried (probably not enough) to do this for others plugins (like Distribute elevation) and I wasn't able to do it.
Probably Puybaret could give us a hint howto do it without hacking the main program.
...not hidden away in the plan menu.
There is also some icons on the toolbar.
[Jul 18, 2025, 2:30:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I noticed the icon, much easier than the menu. The funny thing is that I do edit room points a lot but always with the mouse in the 2D view because the points easily snap to corners or another room with magnetism.
Emmanuel Puybaret can probably give a hint IF there is a function for it that is accessible from a plugin. (My guess is that its a Swing JPopupMenu you need access to for adding an item.)
[Jul 18, 2025, 3:11:26 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
