Total posts in this thread: 6
Previous Thread This topic has been viewed 134 times and has 5 replies Next Thread
FabioG75
Italia
My project has a room lighter than the other ones
Hello,
I made the project of my house with all rooms in darker mode, in order to use it inside home assistant so that when I light on a light, the room illuminates.
But even if I see into the project all dark rooms, when I save the photo, I get the living room clearer than the others, as if the lights are on but it's not.
Could you help me to understand why?
I'd like to attach the project file but I don't know how to do.
[Aug 15, 2025, 9:13:50 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: My project has a room lighter than the other ones
Upload the project file to a file host like mediafire.com and post the download URL here. Make sure you use the "Save and compress" function before uploading, it will result in the same .sh3d file but with a much smaller file size.
[Aug 15, 2025, 8:57:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
FabioG75
Italia
This is the link to my project:
https://www.mediafire.com/file/uefrkiprre0d3od/casa.zip/file
[Aug 15, 2025, 11:34:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
First of all: you have a single cabinet ("contributions") outside of the house that is huge in object size. Remove it and your project will reduce in size to a tenth of what is is now.
The living room has a single light Sorgente luce bianca in the center that has its power setting still at 100%. It displays as cross in a circle in the 2D view.
[Aug 16, 2025, 7:33:35 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
MarioSambol
Croatia
I usually separate the floor plan of the building, the furniture in the individual rooms, the ambient lighting, and the lighting on individual pieces of furniture. In a way that for each part I create a new floor plan on the same level. That way I have the ability to simply hide or show a single level with its associated objects. This is usually my procedure when creating a new project.
[Aug 16, 2025, 9:21:57 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
FabioG75
Italia
Ok, thanks.
I fixed the issue and now I get the living room as the other rooms.
[Aug 17, 2025, 9:33:01 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
