Help with vaulted ceiling
I used these instructions to create a vaulted ceiling:
1. Draw your room walls at the standard height. 2. Create a new level above the existing one. 3. Go to the new level and draw sloped walls that rise from the level below. 4. Adjust the "Height at start" and "Height at end" for these new walls to create the desired peak. 5. Uncheck "Show ceiling" for the lower level and "Show floor" for the upper level to create a seamless look. 6. Select "Display all levels" from the 3D View menu to see the sloped ceiling in the 3D view.
This worked perfectly, but only the first time. Subsequent attempts have left me with a flat roof hovering over the peaks of the sloped walls. What am I missing?
Re: Help with vaulted ceiling
On the lower level uncheck both "Display ceiling" and "Flat ceiling only". On the upper level uncheck "Display floor" and "Flat ceiling only". That should do it.
If you have trouble with getting a nice alignment between walls: On the upper level do not join the sloped walls with the straight walls or do not use straight walls between the sloped walls. Make sure the sloped walls align with the outside of the lower walls. If you get an open space between the lower and upper level because there is no floor on the upper level: add the floor thickness as defined for the upper level to the height of the lower walls. This will extend the lower walls to the bottom of the sloped walls.
An alternative: don't use the ceiling options at all, uncheck them for both levels. Then use the Roof Generator plugin to create a nice roof. This roof has its own (sloped) ceiling. Roof Generator plugin v5.0
