Colombia
Archway-Is it possible to create one ? [for Home Interior or Garden Exterior]
Is there a way of forming a Garden Archway? Is it not possible to set the 'Start Elevation' of a Wall,[like it is for a Window or a Door],and then use a series of Sloping Walls set at different Elevations to construct a basic Arch form? It would be nice though,to be able to achieve this through the use of a series of Elevated Sloping Walls to which one could set the varying Slopes on both the Top AND Bottom surfaces.
Re: Archway-Is it possible to create one ? [for Home Interior or Garden Exterior]
Rabbit:
Yes, it's possible. See example below. Made with SH3D; took me about 5 minutes.... Original file is included.
Based on the phrasing of your question, I think this is not what you mean (but it IS what Google Images thinks a garden archway looks like). So, I made a several more garden archways that might be closer to what you are looking for. Except for the "invisible box", all parts are standard SH3D parts that you can find in the models section.
Emmanuel, if you read this, please note the shadow of the invisible box on the left. It shouldn't be there, but maybe it's because that box is grouped with the arch above it.
---------------------------------------- garden arch.sh3d
(202720 bytes)
(Download count: 718)
[Edit 1 times,
last edit by hansmex at May 8, 2010, 10:01:11 AM]
