Posts: 18   Pages: 2   [ 1 2 | Next Page ]
Previous Thread This topic has been viewed 9001 times and has 17 replies Next Thread
mariora
Italia
smile print on pdf does not work in my linux box
Hallo! Great program, I have linked the url to all my friend!
I am working with it since yesterday with Ubuntu 10.04, and I have few problems that I am going to solve. Only one is important: I cannot save in pdf Format. The file that sweethome create is not readable, and has a 0 Bite length.
what can I do?
Thank you, mariohttp://www.sweethome3d.eu/support/mvnplugin/mvnforum/images/emotion/smile.gif
[May 10, 2010, 8:58:14 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: print on pdf does not work in my linux box
If you have no error message dialog, then there must be an error printed in the console when you launch SweetHome3D command under the console.
[May 10, 2010, 9:12:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Mariora:
Strange... on my Ubuntu 10.04 I get a perfect PDF...
[May 10, 2010, 10:19:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mariora
Italia
Yes, i have no error message dialogue, what I have to do for launching SweetHome3D commend under the console to see if there are errors printed?
thank you for the help
mario
[May 11, 2010, 6:46:51 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Select Applications > Accessories > Terminal.
Drag and drop SweetHome3D icon in the Terminal window.
Type enter in the Terminal window to launch program.
[May 11, 2010, 7:17:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mariora
Italia
I have launched SweetHome3D from the terminal, I have imported a house and then I have tried to print in PDF. Below I report the error message:
mariora@mariora-desktop:~$ sweethome3d
java.lang.NoClassDefFoundError: com/lowagie/text/DocumentException
at com.eteks.sweethome3d.swing.HomePane.printToPDF(Unknown Source)
at com.eteks.sweethome3d.viewcontroller.HomeController$30.call(Unknown Source)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at com.eteks.sweethome3d.viewcontroller.ThreadedTaskController$1.run(Unknown Source)
at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.lang.ClassNotFoundException: Class com.lowagie.text.DocumentException
at com.eteks.sweethome3d.tools.ExtensionsClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at com.eteks.sweethome3d.tools.ExtensionsClassLoader.loadClass(Unknown Source)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
... 12 more
can you understand where is my problem?
Thank you mario
[May 12, 2010, 8:42:14 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I think the iText-2.1.7.jar file is missing in the subfolder lib in folder SweetHome3D-2.3. Can you check please?
[May 12, 2010, 11:13:56 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mariora
Italia
I have found the file /usr/share/sweethome3d/SweetHome3D-2.3.jar using the "locate" command.
(mariora@mariora-desktop:~$ locate SweetHome
/usr/share/sweethome3d/SweetHome3D-2.3.jar)
Inside it (after double clicking on it) i have could seen various files, and among them the file iText-2.1.7.jar
I have no directories named SweetHome3D-2.3. I have to extract SweetHome3D-2.3.jar? and if yes, in which way?
I am sorry, I know I am clumsy
mario
[May 12, 2010, 3:00:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
ChrisOfBristol
I am running Ubuntu 11.04 and have exactly the same problem as mariora, - the PDF file is empty. I get no error message, and have checked for the presence of iText-2.1.7.jar.
[Oct 8, 2011, 4:18:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Chris,
I also use Ubuntu 11.04 and have no problems.
Which version of SH3D are you using? How did you install it?
You could try and use GetDeb for an easy install.
[Oct 8, 2011, 4:55:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
