Total posts in this thread: 5
Previous Thread This topic has been viewed 3959 times and has 4 replies Next Thread
fhoofman
How to add a fixed window above a door?
confused
How do we add a fixed window above a door?
when I add a window above a door, when I looked at 3d, the window & door become mix and unseen. can somebody tell me how?
thax
[Jul 22, 2010, 4:01:48 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How to add a fixed window above a door?
fhoofman:
SH3D does not allow to insert an object (partially) above another object. For every object that you insert into a wall, SH3D (internally) starts a new wall segment. If you need to insert two objects above each other, or need objects (partially) overlapping, you will need to use a different solution. I will briefly describe two methods.
1 - Use the method described here. It works in the standard SH3D without the use of plug-ins.
2 - If you use the CopyAsNewFurniturePlugin there is a simpler way. Just as in method 1, you will have to make horizontal slices (floors) of your model. Make all the slices next to each other: draw the largest (bottom?) slice first and include all important features for the other slices (floors) in it to assure that things line up correctly. Then copy the entire first slice and position it next to the first slice. Repeat if you need more slices (floors). Adapt all slices until they are completed. Now, click File --> New and open a new instance of SH3D. Highlight each slice in turn and use Tools --> Copy as new furniture . Switch to the other, empty instance of SH3D and paste the slice you just copied. Repeat for the other slices. Align the slices, adapt their elevation, and READY. Save both files: one for the details, the other one with just your assembled model.
[Jul 22, 2010, 7:39:29 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You may read also this subject.
[Jul 22, 2010, 3:02:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
maker
Which brings up two feature requests ;)
1.Export selected as obj (So we don't have to open a separate file to do this. Or we could export the door to Wings3d, add the top part, and re import.)This could be used for adding sloping roofs also.
2. "Create Openings". Rectangular openings which could be fitted with furniture - to make arches, grills etc.
Another alternative is to break the wall at both ends of the door/window. Then add a Group, consisting of Door + Window + scaled box (representing wall above.)
Unfortunately this requires careful aligning which SweetHome3d doesn't have (I think.)
[Jul 22, 2010, 7:11:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
fhoofman
thanks a lot guys
hansmex you help me a lot with your plugin
Puybaret enlighten everything
maker thanks man, next time I ask about roof.
all you guys thanks alot, I success without so many effort thanks to you guys
[Jul 22, 2010, 7:29:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
