Previous Thread This topic has been viewed 2692 times and has 2 replies Next Thread
Dirki
"Print to PDF" doesn't work on my portable version?
When I click in the menu "File" Print to PDF" there are created none working 0 bytes PDF files.
What can I do to create working PDF files?
When I click on an icon like "Create walls" a message appears: "Create walls tip". Activating the check box let it pop up again after the next program start. How can I avoid this?
Actual (none Beta) stable, portable Sweet Home 3D
Windows 7 Premium Home Edition & Vista
[Aug 10, 2010, 1:40:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: "Print to PDF" doesn't work on my portable version?
Until now, portable versions are built by other people and you probably picked up a buggy one unable to record preferences. Please try an other distribution.
By the way, once you found a portable version that works, it would be nice to report it here (you can report also the ones that failed).
[Aug 10, 2010, 10:08:58 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Dirki
Thank you Emmanuel,
I use this one, it is the only actual portable version I could find: http://www.sweethome3d.eu/support/forum/viewt...39EDD926491DCDADF9179268D
I assume, according the none working PDF function it is the same answer.
Thanks again, nice greetings, Dirk
[Aug 10, 2010, 10:36:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
