Total posts in this thread: 5
Previous Thread This topic has been viewed 3149 times and has 4 replies Next Thread
tonut01
Indonesia
Can not save into a flash disc
I'm new to this great SW and have following problem:
I use windows XP and downloaded the SW3D version 2.5 Java Web Start with Java version 1.6.0_21
I created a file and already saved in my Laptop. Now I have to print it with another desktop PC, which is connected to a printer. So I try to save my file to a flash disc; but it always appear following text:" Can't save home in F:\...."
I already try to rename it or even copied to a new file and try to 'save as' but it do not works. I can't also create a PDF file in this flash disc.
It's great if you can help me to solve this matter.
Thanks
[Aug 18, 2010, 2:05:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Can not save into a flash disc
I'm under Mac OS X so I can't test your problem because flash drives are handled differently under Unix systems.
Could anyone with a Windows PC confirm this problem?
The workaround is to save on your disk then copy the file to your flash disk out of Sweet Home 3D.
[Aug 18, 2010, 3:52:22 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
tonut01
Indonesia
Mr Puybaret,
Thanks for your reply.
As your suggestion I do: Copy the file directly from my HD to Flash disk; but it appears:" ERROR COPYING FILE OR FOLDER ...CANNOT COPY {FILE-NAME}: the directory or file cannot be created "
So it still not works.
Another questions: I need only the plan. Can I save only the plan individually as a JPG file? Because I need only the plan for my project not the 3D.
Thanks anyway
[Aug 18, 2010, 4:48:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You must have a problem with your flash disk!
Check if it's not write protected, check if there's enough free space on it and/or try to copy an other file.
[Aug 18, 2010, 5:20:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
whippetsleek
No problem here, I have Windows Vista. Maybe update the USB driver?
[Aug 19, 2010, 6:47:38 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
