Total posts in this thread: 2
Previous Thread This topic has been viewed 3840 times and has 1 reply Next Thread
pgeee
external monitor rendering badly 3d
hi, this is not an issue with just SH3D, but I wondered if anyone has encountered this. The 3d pane on my external Acer monitor appears blank, but if I drag the mouse over it, the image appears behind where the mouse has been dragged. I have latest directx, and graphcs drivers , but the noteboom is only a standard Toshiba Satellite Pro. It renders fine on it's own LCD
[Aug 23, 2010, 1:11:49 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
db4tech
Re: external monitor rendering badly 3d
Hi pegee,
What OS are you using?
Have you tried setting the external monitor as 'Main' instead of running it as a secondary display. If doing that causes the 3D view to work properly, then I'm guessing the graphics chip in your notebook isn't able to handle two OpenGL 3D display overlays.
If using XP, one other thing to check, make sure graphics acceleration is set to full.
Lastly, have you tried running Sweet Home using the DirecX fix, see if that works as a secondary display? Have a read here.
db4tech
[Aug 23, 2010, 4:04:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
