Total posts in this thread: 5
Previous Thread This topic has been viewed 2617 times and has 4 replies Next Thread
afattahi
smile Portability
Hi
I have downloaded Home3D Windows installer, and install it in E:\Program Files\Sweet Home 3D.
Now if I move the content of "Sweet Home 3D" folder, to other computer will it run ? Do i need any other files?
On the other words, is Sweet Home 3D, portable ?!
Regards,
Alireza Fattahi
[Sep 6, 2010, 11:40:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Hampi
Re: Portability
I'm guessing it will work, except the automatic open of SH3D Files, because this is not registered on your computer.
I tried to move the folder on same computer and everything still works. So if you have installed the java on the new computer it should work...
[Sep 6, 2010, 4:05:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Portability
Hampi, you don't have to install Java when you installed Sweet Home 3D with its installer, because that version is coming with a copy of the Java Runtime Environment (except under Mac OS X where Java is always preinstalled).
Alireza, you can move the folder where Sweet Home 3D is installed to an other computer, but you'll loose:
- the associations between Sweet Home 3D and SH3D, SH3F, SH3T and SH3L file extensions,
- the preferences you set in the program,
- the 3D models and textures you imported in Sweet Home 3D catalog.
If you really cares about portability, try one of the portable versions available on the Internet.
Please read also the FAQ How can I transfer the furniture I imported on an other computer? that might interest you.
[Sep 6, 2010, 6:18:15 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
afattahi
Re: Portability
Thanks,
I found that lost imported models are saved in C:\Documents and Settings\<UserName>\Application Data\eTeks\Sweet Home 3D
Is it possible that we configure SweetHome3D to use other folder as its home.
For example the current folder which it is already installed!
[Sep 7, 2010, 10:37:11 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Portability
You can't configure an other folder at this time.
Note that portability feature is part of Sweet Home 3D roadmap.
[Sep 8, 2010, 6:53:50 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
