Total posts in this thread: 5
Previous Thread This topic has been viewed 3997 times and has 4 replies Next Thread
error message on exporting to SH3F
Emmanuel,
While trying to export all furniture an error message appeared I haven't seen before. This happened in both v2.6 and v3.0. Do you know what went wrong?
[Nov 22, 2010, 11:18:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: error message on exporting to SH3F
Hans,
There must be a 3D model of an imported piece of furniture that is wrong.
- Stop Sweet Home 3D,
- Open .eteks/sweethome3d/preferences.xml in your home directory with any text editor,
- Search the line that contains Content315000321816400142.pref,
- In that line note the number after the "furnitureModel#" text,
- Find the line that contains "furnitureName#" followed by the same number, and note down the name of the piece of furniture that caused the problem,
- Close the text editor and send me /home/hans/eteks/sweethome3d/Content315000321816400142.pref if possible so I can test where the problem comes from,
- Open Sweet Home 3D and delete the piece of furniture you found from the catalog.
[Nov 23, 2010, 12:20:17 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Emmanuel,
Thank you for your reply. This is what I found:
Content315000321816400142.pref points to
<entry key="furnitureModel#39 ">jar:file:Content315000321816400142.pref!/models/Composant%235 .dae</entry>
points to
<entry key="furnitureName#39 ">bed, red #5</entry>
or did you mean
<entry key="furnitureName#235 ">Light Cube Two</entry>
When inspecting the models, I could see it's the second one, which I already have deleted. It was an experiment in transparency. Still, if it interests you, the pref file is attached.
Attachment Content315000321816400142.pref (13677 bytes) (Download count: 311)
[Edit 1 times, last edit by hansmex at Nov 23, 2010, 12:39:55 AM]
[Nov 23, 2010, 12:39:41 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
I meant furnitureName#39 therefore "bed, red #5"
[Nov 23, 2010, 12:59:18 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Emmanuel,
Thanks once again. I deleted the bed as well.
[Nov 23, 2010, 9:12:01 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
