Previous Thread This topic has been viewed 3155 times and has 2 replies Next Thread
mitamita
Italy
Furniture icons in plan_Top view not possible
Hi everybody,
I've recetly installed Sweet Home version 3.0 but I cannot display the furniture items properly. I just see squared icons.
In "Preferences" window, the selection between Top View and Catalog icons is not possible; I just see it in grey color.
I've already tried all the suggestion written in the FAQ (updated drivers and Java version - 1.6.0_22).
I'm using a laptop FujitsuSiemens with Windows XP.
I've also tried to run Sweet Home 3D with an older version of the Java 3D library, as suggested in the FAQ and this seems working but if I close it, I cannot run the software a second time. It symply doesn't start!
I'm stack. What can I do?
Thanks
[Dec 7, 2010, 3:54:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Furniture icons in plan_Top view not possible
If the DirectX solution didn't solve your problem (the older Java3D library solution should be used as a very last solution), I'm afraid I don't have any other solution to propose. If Top View is a preferences option, it's to let people use Sweet Home 3D nevertheless.
[Dec 7, 2010, 4:28:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Mita,
1 - You could consider installing Ubuntu on your computer. Using Wine 2 you could even run most Windows XP programs.
2 - Or, you could install Ubuntu side by side with Windows XP using Wubi, and run SH3D under Ubuntu, as I do.
[Dec 8, 2010, 12:10:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
