Total posts in this thread: 9
Previous Thread This topic has been viewed 6617 times and has 8 replies Next Thread
SilentStrider
using own textures to show posters?
Hi there
I tried to put an image onto a wall and then just change the texture (and the size of the object) to a pic of the actual poster that is on my wall there. Nearly all works fine, but when I click ok it shows the picture I used as texture as tiles, four ones with the point in the middle of the object.
Is there an easy way to just use pictures on my hard disk to cover posters with it in the program? My consideration was just to copy an existing model and change the texture of it with another picture (where I shouldn't chose the mirror for it *slight cough*)
[Dec 18, 2010, 3:35:39 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: using own textures to show posters?
Strider,
Yes, there is an easy way, if you think for a bit...
A texture is a repeating image, applied to a wall, floor, ceiling or other object. So, for a poster you want it to repeat just once.
Import (or Modify) your texture so that its size corresponds with the size you want, let's say 60x90 cms.
Now apply this texture to a box of 60x90 cms. Et voila!
[Dec 18, 2010, 3:52:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SilentStrider
I did kinda exactly this... let me make some screenshots.
Lets say I use a picture of the Niagara-Falls and want to give it a new texture so I can put on another image
next I import the texture and gives it the size of the actual poster (which is 157cm width and nearly the 49,95cm it says (actual its 53cm height, but thats due that this is a image))
now I change the object to match my needs
after what you have said it should work now, but look yourself:
but the image looks like this
So you see there is a point in the object where it tiles the texture around it.
[Dec 18, 2010, 5:16:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Strider,
I'll have to check on this. Someone reported this behaviour before on the forum. Not sure if there's a solution to it.
[Dec 18, 2010, 5:24:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Strider,
Check out this thread.
[Dec 18, 2010, 5:28:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SilentStrider
thanks for showing the thread, I'll try that
[Dec 18, 2010, 5:44:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Either use the other side of your box, or reduce its depth to a very small value.
[Dec 18, 2010, 7:08:59 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
wrosun
Nepal
peace SilentStrider
I think you are trying to make a picture frame for your wall am i right?
Well i also have been thinking on asking Puybaret if he could make a frame where any picture can be inserted by changing the texture but i found another way using box to create own frame so i dropped out the question.....here is a picture frame with the picture you posted.
Picture Frame
There is a pattern how the texture in the box works:
1. on one side of the box ( lets say back) the texture is applied as a reflected image so you get a image opposite than the image you chose and it is same for bottom part also.
2.And on other side( i.e front) it is same like the picture and on the top also it is same.
FRONT:
TOP:
3. other two sides do not take texture..
so keep that in mind if you like to create a picture frame of your own..
[Dec 19, 2010, 10:11:39 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
SilentStrider
thank you very much :)
[Dec 21, 2010, 1:52:02 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
