Total posts in this thread: 4
Previous Thread This topic has been viewed 33445 times and has 3 replies Next Thread
mfluckiger
Canada
using dwg files
I have a dwg file of a floor plan that I would like to use in sh3d. Can anyone tell me if there is any way to use this existing drawing as a base rather than reproducing it from scratch?
Thank you,
[Feb 2, 2011, 4:28:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: using dwg files
You should export your DWG file to a format supported by Sweet Home 3D, meaning OBJ, DAE/Collada, 3DS or LWS format, and import it as a piece of furniture.
But don't expect that the walls, floors and ceilings defined in your file will be handled as walls and rooms in Sweet Home 3D.
[Feb 2, 2011, 4:37:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: using dwg files
Michael,
There is no direct way to import DWG files into SH3D, not as a basis for further drawing, nor as a background image.
You can try to import a DWG file into Blender, then export it as an OBJ file, which in turn can be imported into SH3D. Note, however, that such an OBJ file cannot be edited in SH3D, because it will function as if it were a piece of furniture.
[Feb 2, 2011, 4:37:46 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
mfluckiger
Canada
Re: using dwg files
Thank you both for the responses. I'll give this a shot,
[Feb 2, 2011, 6:46:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
