Total posts in this thread: 1
Previous Thread This topic has been viewed 3553 times and has 0 replies Next Thread
connomar
Wall Drawing Preferences
Hi, I've seen some discussion on various ways of drawing a room, but I wonder if a fairly simple solution might work best. If we were able to select whether the length of a wall was measured from inside edge of the adjoining wall, then drawing a room to given dimensions would be much simpler.
Also, would it be possible to press a secondary key and lock the vertical or horizontal plane whilst moving a wall. i.e. Inside dimension of a room is 60cm out and I want to move the wall. At present, this doesn't seem possible in a precise way.
Thanks
Martin
[Apr 9, 2011, 4:40:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
