Previous Thread This topic has been viewed 3346 times and has 2 replies Next Thread
steffi1981
Germany
I can't open older projects with SH 3D in version 3.2
Hello everybody,
I have some older projects (created with version 2.0). But I can't open this projects with my new version 3.2.
If I select the relevant file, the project is visible for a very short time, but then the total SH 3D terminated. sad
Could someone help me?
Steffi
[Apr 21, 2011, 12:48:23 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: I can't open older projects with SH 3D in version 3.2
When the program crashes, it's generally because of the 3D part.
But there was no special changes between these two versions on the 3D side.
Maybe you changed your computer or updated your system meanwhile.
Please install Sweet Home 3D 2.0, check if you can open your files, then uninstall it, install Sweet Home 3D 3.1, try to open your files again and report if it worked or not (we'll see for Sweet Home 3D 3.2 beta version later if you don't mind).
[Apr 21, 2011, 1:14:42 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
steffi1981
Germany
Hello Emmanuel,
first of all, thank you for your prompt help. But I was on holiday at Easter, so that I can answer only now.
You're right, I have newly installed my PC. Now I have done the both installations and I checked my files. It works fine with version 2.0. With the newer version 3.1 it crashed, as described.
best regards
steffi
[Apr 27, 2011, 10:10:57 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
