Total posts in this thread: 4
Previous Thread This topic has been viewed 4850 times and has 3 replies Next Thread
Mitch
Create "upside-down" sloped walls
I want to try to make a wall with a sloping side. I found the slope options in the Modify screen of a wall. But it seems I can only make sloped walls that are wide at the bottom and narrow at the top.
I can make a wall like this:
|XX\
|XXX\
|XXXX\
|XXXXX\
But I want something like this:
|XXXXX/
|XXXX/
|XXX/
|XX/
Is this possible?
[May 25, 2011, 7:10:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Create "upside-down" sloped walls
It's not possible.
But you can import a triangle placed beside a box to simulate the same thing.
[May 25, 2011, 7:24:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Mitch,
Or you can draw the wall in its upright position, then use the CopyAsNewFurniture plug-in, then Export to OBJ format, then Import furniture and turn it 180 degrees during importing. See the Sloping roof manual (PDF) for more info on this workaround.
[May 25, 2011, 7:29:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Mitch
Thanks for the answers.
I tried the "triangle" approach and that worked fine.
[May 26, 2011, 6:22:16 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
