Problem with open door size
Hi there Tks for the solution on the other post.
I'm in Brasil and here the walls has 10cm not 7,5 .
I configured the size of the walls and its ok.
The problem is with half open door.
When I put the open door at the wall, its gets the wall thiknes, its ok, but the size of te door at 3d view became bigger, not the open area, but the door it self.
in a 90cm door, the leng goes to 123cm, and is not possible to change it.
Re: Problem with open door size
Clovis,
There is a simple solution for your problem. First insert a hatch that has the size of your door, then insert the door in the hatch using the cursor keys or exact coordinates. That way the door doesn't resize. You can find the hatch here and here.
There is also a more complex solution, which I have copied from the forum into my Tips & Tricks manual, which you can find here.
