Total posts in this thread: 5
Previous Thread This topic has been viewed 15453 times and has 4 replies Next Thread
100matolog
How do I change the angle to the wall was less than 15 degrees?
[Jun 19, 2011, 8:14:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How do I change the angle to the wall was less than 15 degrees?
If you hold down the SHIFT key while drawing a wall you can draw walls at any angle.
You can also disable Magnetism in the Preferences, but then you can't insert doors/windows anymore.
[Jun 19, 2011, 8:40:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
100matolog
Thanks
[Jun 20, 2011, 5:08:59 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
TorQueMoD
Canada
You need to hold down ALT as of version 6.1.2, not shift.
[Nov 19, 2019, 11:22:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
The magnetism shortcut changed to Alt (cmd under macOS) with version 4.0 in 2013, after this thread was started. Thanks for reporting the change even a long time after.
[Nov 20, 2019, 7:49:55 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
