Previous Thread This topic has been viewed 4609 times and has 2 replies Next Thread
polo2010
applause Invisible cylinder
I am using the invisible box and now try to do a similar one but as a invisible cylinder - I check the box mtl and obj, compare the invisible box's mtl and obj, now how to do an invisible cylinder?
[Jun 29, 2011, 3:30:53 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Invisible cylinder
In a mtl file, the number following d matches how transparent is a material from 0 (fully transparent) to 1 (fully opaque).
You can try on a cylinder but don't expect to make round holes in walls with such an object.
If this was your final goal, see this thread for a workaround.
[Jun 29, 2011, 4:22:49 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
polo2010
I am trying the work around. I don't want a round whole in the wall - I am using the "wall" to create a 20 cm thick 300 x 500 ceiling and place the new "round tool" 10x10 so I get a series of small round wholes. I copy as new furniture and elevate to my ceiling height. Then I give texture and place small light bulbs inside the small wholes to get an embedded light source, that you often see in ceilings and canopys in interior design magazines. I am not good at adding light sources, but it seems to come out fine.
[Jul 4, 2011, 7:40:46 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
