Re: electric installation
Even if it could come sooner than expected, the current version of Sweet Home 3D doesn't have any tool to help you draw "free" colored lines in the plan. If you need some electric symbols, you could check if the font used by Sweet Home 3D supports the Unicode symbols that could help you. If you want to draw dimensions on the walls, use the dimension creation tool and double click on the walls where you want a dimension.
i mean the dimensions from walls in x,y AND Z axis.
Germany
noxx,
as for sh3d, you can only add measurements in 2D for the top-view, there is no solution for adding those for the vertical axis. this would require a side/front view. sh3d is used to be a "Möbelschubser" (long time ago), with an excellent(and growing) surrounding design engine (thanx for that).
so, if you need a "real" installation software, get eplan, or acad, or whatever.
macfrog
p.s.: if you consider revealling your home as Germany, you might get answers in the "foreign language" chapters of this forum in your natives...
