Previous Thread This topic has been viewed 12127 times and has 12 replies Next Thread
inkstain44
How can I access auto recovery files? I just lost all of my work!
I've been working on a project for hours on end, saving it constantly; or so I thought. When I finally decided to close the project I had noticed SweetHome gave the alert that any unsaved changes would be lost. I saved it a few times to be sure, then closed it finally, ignoring the message. When I went to reopen it, I was back to the beginning stages of my project. I lost hours of work and an immense amount of progress. I'm worried I wont be able to recover it, because Sweet Home isnt actually saving anything. When I try to save progress, the little save bar flashes, but nothing actually saves. Anyway, where can I look on my computer to look for the recovered files, I have a Mac.
[Jul 29, 2011, 10:49:41 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How can I access auto recovery files? I just lost all of my work!
Have a look at : Library/Application Support/eTeks/Sweet Home 3D/Recovery
[Jul 29, 2011, 11:57:01 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Your description is quite confusing. sad
If you exited the program just after you saved, there won't be any additional message, except if save operation failed! Did you have a message telling you that the save operation failed?
Are you sure you're opening the file you saved? Maybe you opened an old copy.
If inkstain44 had no error message, his file should be saved and recovery folder will be empty (recovery folder is to recover files in case of a program crash).
[Edit 1 times, last edit by Puybaret at Jul 29, 2011, 3:34:46 PM]
[Jul 29, 2011, 1:20:07 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
inkstain44
There was no error message, but it does seem as if the save did fail
[Jul 29, 2011, 2:56:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
inkstain44
And there is absolutely nothing in the recovery folder :/
[Jul 29, 2011, 2:57:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
inkstain44
I'm sorry about the clarity of the description.. um.. when I saved the project, it seemed as if it was performing just fine, however, when I went to close it, I would get the message that my changes would be lost. So it seems as if it wasn't properly saving
[Jul 29, 2011, 3:01:29 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
inkstain44
And now the issue is that Sweet Home will not save anything I do. I started re-building, and I'm having the same issue with saving. When I save and go to close the project, I get the warning message. I tried copying what was left of the home into a new project, and it still will not save. I have gotten no error messages.
[Jul 29, 2011, 3:08:32 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Really really strange. sad
Did you ever succeed to save something with Sweet Home 3D?
Can you try this, please:
- Open Java Preferences in Applications/Utilities folder
- Click on Advanced options tab, and select Display console option
- Run Sweet Home 3D Java Web Start version proposed in Download page
- Try to reproduce your problem by saving your document
- Copy/paste here the text that will appear in the window console that will be opened with Sweet Home 3D. It should be something starting by Exception in Thread...
If no exception is displayed in the console, please describe the exact minimum steps of a reproducible test case.
Thanks for your help.
[Jul 29, 2011, 3:32:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
inkstain44
I wasnt sure how much to copy. :
at java.lang.Thread.run(Thread.java:613)
java.lang.IllegalArgumentException
at java.util.zip.ZipInputStream.getUTF8String(ZipInputStream.java:304)
at java.util.zip.ZipInputStream.readLOC(ZipInputStream.java:243)
at java.util.zip.ZipInputStream.getNextEntry(ZipInputStream.java:73)
[Jul 29, 2011, 9:15:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
inkstain44
If that isnt exactly what you wanted, here's a screenshot: http://www.facebook.com/media/set/?set=a.1015...36&type=1&theater
[Jul 29, 2011, 9:23:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
