Bug in connecting rooms under doors?
Emmanuel,
Recently I made a model where I used a self-made invisible doorframe/hatch to make an open connection between two rooms. After making some changes to the rooms, I noticed that the floors didn't connect correctly "under' the frame. I saved the model, re-opened it, deleted floors and inserted them again, but the problem is persistent.
When I make a new test model using the same frames, there is no problem, and floors are correctly connected.
I attach the file in question.
bug in floors?
[Edit 1 times,
last edit by hansmex at Aug 16, 2011, 12:29:37 PM]
