Problem with old versions - problém so staršou verziou
Ahoj, mám problém s otváraním súborov urobených v staršej verzii SH3D. Robila som ich v rokoch 2008-2009. Teraz som ich chcela otvoriť, musela som si stiahnuť novú verziu a tam mi to už nejde otvoriť. Dá sa niekde stiahnuť staršia verzia platná v r.2008-2009? Alebo je iný spôsob na otvorenie súborov? Díky. Hi, I have a problem with opening files made in an earlier version SH3D. I did it in 2008-2009. Now I wanted to open it, I had to download a new version of me and there's not already open. Can I download an older version somewhere valid r.2008-2009? Or another way to open files? Thank you.
Re: Problem with old versions - problém so staršou verziou
Monika,
As far as I know, all new versions of SH3D can open files from older versions. Your description of the problem isn't very clear, so it's difficult to help you. What is your operating system (Windows, Mac, Linux?)? Which version of SH3D are you using now? What is the exact problem?
There aren't many Slovak users here, as far as I know...
I guess pointing to the source code won't be very useful for cimik! Older installer versions are here, but there should be no problem with an older file. Sweet Home 3D has always been upward compatible (and will probably always be). Maybe your file was altered during a transfer.
Keď sa snažím otvoriť súbor, začne sa načítavať SH3D a po chvíli sa otvorí okno s nápisom ERROR Can't open home a adresa súboru. Môj operačný systém je Windows vista, mám ho už 4 roky, nemenila som ho. Teraz som si stiahla verziu SH3D 3.3. Tak neviem, kde by mohol byť problém. Excuseme my english, is not very good. When I try to open the file, it starts to load SH3D and after a while, a window that says ERROR Can not open file home and address. My operating system is Windows Vista, I have already 4 years, I have not changed it. Now I can download a version SH3D 03.03 So I do not know where he could be a problem.
