Previous Thread This topic has been viewed 4485 times and has 2 replies Next Thread
Mitsaki
Setting the exact location of the export
Hello again,
what I want to do is to modify the existing interface, so that when the export to .obj file runs, the window, that the user uses in order to save the project, doesn't run and the project is saved directly in a desirable path.
Do you know where I should look to find the place that this is done, in which class?
I would really appreciate it.
Mitsaki
[Nov 6, 2011, 7:24:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Setting the exact location of the export
The path of the SH3D file is simply returned by the getName method of the Home object.
[Nov 10, 2011, 12:00:42 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Mitsaki
To do what I need, I just used the class
FileContentManager
and I added blocked comment in the row 471-475, so the dialog box does not appear, like this and as savedName I put Our_home.
String savedName;
savedName = "Our_home";
// Use native file dialog under Mac OS X
/* if (OperatingSystem.isMacOSX()) {
savedName = showFileDialog(parentView, dialogTitle, contentType, name, true);
} else {
savedName = showFileChooser(parentView, dialogTitle, contentType, name, true);
The only thing that is missing now is to set the file, so that it is not saved automatically inside the sweethome3d folder, in workspace, but outside of it.
[Nov 10, 2011, 3:42:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
