Total posts in this thread: 8
Previous Thread This topic has been viewed 7202 times and has 7 replies Next Thread
fanyam
Bay Window
Could you please tell me where I can find 3D Bay Window with 90 degrees, sort of like a box window outside the wall. I could not find on the web... :(
Thanks
[Nov 21, 2011, 4:00:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Bay Window
Did you look in the Sketchup Warehouse?
The search term "bay window" gives a lot of results...
[Nov 21, 2011, 5:07:08 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
fanyam
Re: Bay Window
Yes, I did. But I could not find the one angled back 90 degrees
[Nov 22, 2011, 12:16:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Bay Window
Can you show a picture of what you are looking for?
[Nov 22, 2011, 12:46:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
fanyam
Re: Bay Window
Hi Hans, I have uploaded a picture to below : http://sourceforge.net/tracker/?func=detail&a...id=152568&atid=784668
thanks
[Nov 24, 2011, 1:35:35 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Bay Window
This is more a room extension than a bay window, in my view. So, I would treat it as one by drawing walls and inserting windows. That way you can have a floor and ceiling as well. Note that you can stack two windows on top of each other, if the window configuration should closely match your picture.
bay window.sh3d
[Nov 24, 2011, 9:07:29 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
fanyam
Re: Bay Window
I'm not sure if it could work as I need to rise in floor level and lower the ceiling height in the window area in order to match the actual status. Let me try and update you later. Thx so much Hans.
fanyam
[Nov 26, 2011, 4:23:38 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Bay Window
Fanyam,
There's a solution for everything.
1 - Use SH3D version 3.3 with the CopyAsNewFurniture plug-in installed.
2 - Design your "bay window"
3 - Use boxes for floor and ceiling
4 - Use CopyAsNewFurniture and then Export to OBJ format to export your window as a model.
5 - Use Import furniture to use your model.
[Nov 26, 2011, 9:48:10 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
