Total posts in this thread: 6
Previous Thread This topic has been viewed 4642 times and has 5 replies Next Thread
Gibbo
3D view won't select upper level
Hello to all
I am a new user working on a PC with Windows XP. I have built a (minimum) 2 level model of my house, but am having problems with the 3d view. The aerial view is fine and I can run the virtual visitor view of the ground floor, but I can't get the virtual visitor view of the upper floor. When I select display selected level on the ground floor, it works correctly and the aerial view only shows the ground floor. However, when I do the same for the top floor the whole house is still displayed and the visitor refuses to go upstairs!
I have been through all the existing posts, the user guide and the FAQs, but found nothing of help.
Can anyone help?
[Dec 30, 2011, 11:34:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: 3D view won't select upper level
John,
To view the upper level(s) of your design, right-click in the 3D preview window and select Display all levels; this will show all levels at the same time.
If you want to see the topmost level, right-click in the 3D preview window and select Display selected level; this will display the level that is activated with the Level tabs above the 2D window, and all levels below that level. So if you have 3 levels and want to see the lower 2 levels, select Level 2. If you want to see all three levels, select Level 3.
[Dec 30, 2011, 11:59:47 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Gibbo
Thank-you, this has solved half the problem, as I didn't expext selected level to show all levels up to the selected level. I have now managed to view upstairs by modifying the eye-level in the 3D modify options to a suitable height. Is this the only way to move the visitor between floors, or am I missing something?
Getting there slowly!
John
[Dec 31, 2011, 12:18:35 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
John,
Yes, and no.
Yes, it's the only way to move the virtual visitor around.
No, because after selecting a view position, you can store it using 3D view -> Store point of view.
With 3D view -> Go to point of view you can then revisit your view points by selecting one of the view points from the list.
[Dec 31, 2011, 3:15:51 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
What about using the eyes elevation indicator available in the back of the virtual visitor in the 2D plan?
[Dec 31, 2011, 9:02:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Gibbo
Thanks to all. I am up and running now.
John
[Jan 1, 2012, 12:57:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
