Re: unregular-box
The easiest way to create this kind of irregular shape would be with Art of Illusion: - click on box tool, - draw a box of any size, - select Object > Convert to Triangle Mesh menu item, - select Object > Edit Object menu item, - In the object editor, move the vertices like you want, - once done, select Export > Wavefront (.obj) menu item, - import in Sweet Home 3D the generated file.
Poland
Re: unregular-box
You may also download a 30day trial of Autodesk 3ds Max. Creating a cube and modifying it is in one of the first video lessons. Created model can be easily exported to OBJ.
Re: unregular-box
Are you sure that a trial version of 3DS MAX would let you legally create some files that you can use for production?
"Trial licenses are only available as Stand-Alone and are for demonstration or evaluation purposes only. They are not to be used for commercial or for-profit purposes."
In my opinion there are no obstacles in using it for personal needs, but I might be wrong :-)
Re: unregular-box
As lvedin seemed to be satisfied by the AOI solution I proposed, let's think about open source solutions first. Licenses are not shorter to read but definitively gives users more freedom.
