swh3d stops open production file
All of a sudden swh3D refuses to open a file I'm working with. I'm, pretty desperate as I'm already running late with this project.
I enclose the error message I get when launching it app from the terminal
any help appreciated.
Thanks _______________ Error message
chroe@linuXin:~/Programme/SweetHome3D-3.4$ ./SweetHome3D Exception occurred during event dispatching: java.lang.IllegalArgumentException: moveColumn() - Index out of range at javax.swing.table.DefaultTableColumnModel.moveColumn(Unknown Source) at com.eteks.sweethome3d.swing.FurnitureTable$FurnitureTableColumnModel.updateModelColumns(Unknown Source) at com.eteks.sweethome3d.swing.FurnitureTable$FurnitureTableColumnModel.<init>(Unknown Source) at com.eteks.sweethome3d.swing.FurnitureTable.<init>(Unknown Source) at com.eteks.sweethome3d.swing.SwingViewFactory.createFurnitureView(Unknown Source) at com.eteks.sweethome3d.viewcontroller.FurnitureController.getView(Unknown Source) at com.eteks.sweethome3d.swing.HomePane.createCatalogFurniturePane(Unknown Source) at com.eteks.sweethome3d.swing.HomePane.createMainPane(Unknown Source) at com.eteks.sweethome3d.swing.HomePane.<init>(Unknown Source) at com.eteks.sweethome3d.swing.SwingViewFactory.createHomeView(Unknown Source) at com.eteks.sweethome3d.viewcontroller.HomeController.getView(Unknown Source) at com.eteks.sweethome3d.HomeFramePane.<init>(Unknown Source) at com.eteks.sweethome3d.HomeFrameController.getView(Unknown Source) at com.eteks.sweethome3d.HomeFrameController.displayView(Unknown Source) at com.eteks.sweethome3d.SweetHome3D$2.collectionChanged(Unknown Source) at com.eteks.sweethome3d.model.CollectionChangeSupport.fireCollectionChanged(Unknown Source) at com.eteks.sweethome3d.model.HomeApplication.addHome(Unknown Source) at com.eteks.sweethome3d.viewcontroller.HomeController$29.run(Unknown Source) at java.awt.event.InvocationEvent.dispatch(Unknown Source) at java.awt.EventQueue.dispatchEventImpl(Unknown Source) at java.awt.EventQueue.access$000(Unknown Source) at java.awt.EventQueue$1.run(Unknown Source) at java.awt.EventQueue$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.Dialog$1.run(Unknown Source) at java.awt.Dialog$3.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.awt.Dialog.show(Unknown Source) at java.awt.Component.show(Unknown Source) at java.awt.Component.setVisible(Unknown Source) at java.awt.Window.setVisible(Unknown Source) at java.awt.Dialog.setVisible(Unknown Source) at com.eteks.sweethome3d.swing.ThreadedTaskPanel.setTaskRunning(Unknown Source) at com.eteks.sweethome3d.viewcontroller.ThreadedTaskController$1$1.run(Unknown Source) at java.awt.event.InvocationEvent.dispatch(Unknown Source) at java.awt.EventQueue.dispatchEventImpl(Unknown Source) at java.awt.EventQueue.access$000(Unknown Source) at java.awt.EventQueue$1.run(Unknown Source) at java.awt.EventQueue$1.run(Unknown Source) at java.security.AccessController.doPrivileged(Native Method) at java.security.AccessControlContext$1.doIntersectionPrivilege(Unknown Source) at java.awt.EventQueue.dispatchEvent(Unknown Source) at java.awt.EventDispatchThread.pumpOneEventForFilters(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForFilter(Unknown Source) at java.awt.EventDispatchThread.pumpEventsForHierarchy(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.pumpEvents(Unknown Source) at java.awt.EventDispatchThread.run(Unknown Source)
Re: swh3d stops open production file
likaroli, thanks for sending your file. I fixed the problem in your file and sent you the correct file. The issue was different from choe's one, and it came from a DAE file you imported with accentuated letters. I didn't find how to reproduce the bug but found a way to avoid it in Sweet Home 3D. Until next version is released, please remove accentuated letters from 3D models files before importing them.
likaroli, the bug you encountered is fixed in the version 3.7 I just released.
