Total posts in this thread: 7
Previous Thread This topic has been viewed 3821 times and has 6 replies Next Thread
cicliced
PLAN>Modify walls
I have just started using this program and am getting on fine with it apart from there seems to be a few menu options greyed out on the menu, specifically 'PLAN>MODIFY WALLS', so i'm unable to edit the floor colour etc.
Any ideas why this might be?
Thanks
James
[Apr 28, 2012, 4:15:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: PLAN>Modify walls
1 - You have to select a wall, before you can modify it.
2 - To edit a floor, you first have to draw a room, then you can edit it with Modify room.
Maybe it's a good idea to read the User's guide first?
[Apr 28, 2012, 5:18:36 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
cicliced
Hi Hans,
Sorry I meant to say specifically 'MODIFY ROOMS' is greyed out in the menu, so I can't access it. I have created 1 room. The plan is unlocked.
Thanks
James
[Apr 28, 2012, 5:54:18 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
You have to select first the rooms you want to modify. If you want to change them, select all, it's not a problem if the selection contains other kinds of objects.
[Apr 28, 2012, 11:12:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
cicliced
Hi Emmanuel, I have selected the rooms but it still doesn't let me have access to 'modify rooms'. See screen print below...
[IMG]http://i50.tinypic.com/309pmra.jpg[/IMG]
Am I selecting it correctly? Do all the walls have to be 'joined'? it looks like all the walls are joined apart from one wall that just overlaps at the corner and won't connect to the other wall.
Thanks
James
[Apr 29, 2012, 12:44:03 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
cicliced
Here is the link to the file i created if you want to have a look at it.
https://docs.google.com/open?id=0B6ErAvoNHHrUZEVkSTltazZIRWc
You have to click 'file'>'download' at the top left of the screen.
[Apr 29, 2012, 2:25:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
cicliced
i solved it, i didn't have the room corners set, i was just drawing on the initial screen that opened.
[Apr 29, 2012, 3:54:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
