Total posts in this thread: 6
Previous Thread This topic has been viewed 5916 times and has 5 replies Next Thread
ABRanka
Changing colour/texture of PART of an object.
Hello.
I'm wondering about a possibility of changing colour or texture of part of an object. For example: having a chair that is composed from red sit and metal base - now if I change it to e.g. white, both red and metal change. It would be great to get white sit and metal base in this case.
Is it / would it ever be possible?
Regards.
[May 10, 2012, 12:50:49 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Changing colour/texture of PART of an object.
It should be possible in a future version. Future will tell! smile
[May 11, 2012, 1:31:21 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
gap
ey! this is that i would like in walls, i mean, a color base and add some stripes in other colour, or sofas with patterns, it'll be great.
will take longer the future are u talking about?
thankyou.
[May 30, 2012, 7:08:34 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Lynn22
For the chair, if you have it in OBJ format you could re-texture it in any 3D application.
For the wall, build your wall as 2 separate levels (if your wall is 3 m. high, build level 1 at 1 m. and level 2 at 2 m. and no floor in between), give level 1 a color and level 2 a striped texture ;o)
[Jun 1, 2012, 3:15:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
gap
applause Re: Changing colour/texture of PART of an object.
thanks a lot!!!
[Jun 3, 2012, 1:27:40 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
oxygen
Russia
For changing textures of 3D-models I use a custom models and change their textures in Deep Exploration than import models into SH3D.
When I want to add some stripes or another saped objects to the walls, I take a cube or round and change their textures and dimensions (length, width, height) in SH3D and plase them next to the wall. It looks like in this picture:
KT Exclusive_Damasse 6 by pixie Xu, on Flickr
The base of the walls was made in decorative plaster texture, than decorative frames was added on the needed levels. Than I took cubes that comes with program by default and changed thair properties, placed them on needed level. For that cubes I took textures of a wallpaper an murals (the antic lion of Affresco).
[Jun 11, 2012, 11:22:44 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
