Rotate furniture on z-axis
I think there should be a way to rotate furniture on z-axis, istead of only on the x/y-axis. I know this can techincally be done via importing furniture models. But you can only rotate it by 90 degrees each time. When furinture is rotated in the SH3D editor, it can only rotatate on the x/y. Would this be a relatively easy function to add in the neat future?
Thanks! This would remove the need of me rotating them in Blender instead, which can be a suck up a lot of time. Samuel Venable a.k.a. time-killer-games
Re: Rotate furniture on z-axis
Not sure it will happen soon because rotating an object around x or y axis would change its dimensions, and I'm pretty sure this would get too complex for the audience targeted by the program.
[Edit 1 times,
last edit by Puybaret at Sep 5, 2013, 4:26:35 PM]
