Changing shortcuts
Does anybody knows, how can I change the shorcuts?
It sounds very good that the selection shortcuts ends with the first letter of functions like ctrl+shift+w for wall and r for room, but in this case both hands needed to press it, which is wery unconfortable because I need to release the mouse. So I would like to change some, but I do not know how.
Re: Changing shortcuts
Unless you're a programmer able to update the program, it's not possible at this time. There will be probably a pane in preferences able to configure shortcuts.
Thanks,
I have already downloaded the source and I tryed to find the relevant code but it is so big and I only exeperince width Java is the android ecosystem...
It's not in Java code, but in the src/com/eteks/sweethome3d/swing/package.properties resources file. Simply change the values of the keys named AcceleratorKey. Good luck!
