Total posts in this thread: 9
Previous Thread This topic has been viewed 5307 times and has 8 replies Next Thread
adampease
not compatible application version
When starting up sweethome3d on Ubuntu Linux, with several of the plugins, I'm getting the message
Invalid plug-in jar:file:/home/apease/.eteks/sweethome3d/plugins/CopyAsNewFurniture.sh3p!/com%2Feteks%2Fsweethome3d%2Fplugin%2Fcopyasnewfurniture%2FApplicationPlugin.properties:
Not compatible application version
Could someone advise?
[Jun 10, 2012, 3:43:00 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: not compatible application version
What version of Sweet Home 3D do you use?
[Jun 10, 2012, 4:08:43 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
adampease
It's version 2.6, which is the version that installs from the Ubuntu Software Center
[Jun 10, 2012, 5:39:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Use the latest version 3.5.
[Jun 10, 2012, 5:46:20 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
adampease
Thanks Emmanuel, using the latest version solves the problem. Maybe someone could update the version in the Ubuntu repository. That will help other newcomers. Many thanks for the excellent software!
[Jun 10, 2012, 6:50:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
adampease
Well, I may have spoken too soon. I now get a JRE crash, as well as some messages about other plugins being invalid. This is all while trying to follow the "sloping ceiling" tutorial. The crash happens while attempting step 8 on page 8 of the tutorial Furniture->import furniture . I can replicate the crash.
apease@apease-HPdm:~/Programs/SweetHome3D-3.5$ ./SweetHome3D
Invalid plug-in jar:file:/home/apease/.eteks/sweethome3d/plugins/RotateHomePlugin.zip!/RotateHomePlugin%2Fsrc%2Forg%2Faddy%2Fsh3d%2Fplugin%2FApplicationPlugin.properties:
org.addy.sh3d.plugin.RotateHomePlugin
Invalid plug-in jar:file:/home/apease/.eteks/sweethome3d/plugins/DuplicateStylePlugin_version4.zip!/DuplicateStylePlugin_version4%2Fsrc%2FnewPlugin%2FApplicationPlugin.properties:
newPlugin.CopyStylePlugin
# A fatal error has been detected by the Java Runtime Environment:
# SIGSEGV (0xb) at pc=0x00007fcd8ea86b24, pid=9121, tid=140520710752000
# JRE version: 6.0_32-b05
# Java VM: Java HotSpot(TM) 64-Bit Server VM (20.7-b02 mixed mode linux-amd64 compressed oops)
# Problematic frame:
# C [libGL.so.1+0x25b24] __float128+0x64
# An error report file with more information is saved as:
# /home/apease/Programs/SweetHome3D-3.5/hs_err_pid9121.log
# If you would like to submit a bug report, please visit:
# http://java.sun.com/webapps/bugreport/crash.jsp
# The crash happened outside the Java Virtual Machine in native code.
# See problematic frame for where to report the bug.
Aborted
[Jun 10, 2012, 7:10:54 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Sorry I take care only of versions delivered on SourceForge.net. Please contact Ubuntu team directly.
Sorry for the crash, it generally means an issue with the video driver. Hope you can fix it.
[Jun 10, 2012, 9:56:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
adampease
Hi Emmanuel - Just to be clear, the current issue with the crash is with the version from SourceForge.net - version 3.5.
[Jun 10, 2012, 10:31:13 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
adampease
I've replicated the problem also now with both JRE 6 and JRE 7. I've reported the bug to Oracle and will let you know if their feedback indicates that any change in use of Java is needed.
[Jun 10, 2012, 11:38:33 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
