Total posts in this thread: 5
Previous Thread This topic has been viewed 5238 times and has 4 replies Next Thread
stevegalante
Canada
Floors and rooms and floor plan image
I drew some walls of a room without actually drawing a room, but since I needed to put a floor I had to draw a room with the same dimension of the walls, so in other words if you do not draw a room you cannot add a floor, right ?
And one other thing, maybe it's me but, how do you create an image file (*.png, .jpg, ecc.) of the floor plan (not the 3d rendering) ?
Thank you, still newbie here... biggrin
www.stevegalante.com
[Jun 18, 2012, 12:21:14 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Floors and rooms and floor plan image
Yes. Automatic floor generation may appear in a future version, but if it could be handy in many cases, I fear it could get worse for special cases like mezzanine, multiple floor in a room...
You can export the plan at SVG format with the Plan > Export to SVG format menu item, and you can get a bitmap image of the selected plan items with a copy/paste in any image or word processing software (this second solution might not work under Linux).
[Jun 18, 2012, 7:10:03 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
stevegalante
Canada
Thank you, is it possible to delete the area measurement that appears when you draw a room ?
Thank you, it would be nice to have a simple save as image file though.
[Jun 18, 2012, 4:52:31 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Uncheck the Display area check box in its modification pane.
[Jun 18, 2012, 5:25:27 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
stevegalante
Canada
'ppreciated !
[Jun 18, 2012, 6:52:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
