Posts: 23   Pages: 3   [ 1 2 3 | Next Page ]
Previous Thread This topic has been viewed 11302 times and has 22 replies Next Thread
svetl@n@
confused Niches in a round wall?
Hello! I write from Russia!
Thanks big for the program!! Forgive, if bad transfer!
Prompt please how to do niches (or through regiments) in a round wall?
[Jul 24, 2012, 9:34:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
chrispy1970
smile Re: Niches in a round wall?
Take a window without glass (in german it´s called durchreiche) and pace it in the round wall. make th size you want and be happy.
greetz
Chrispy
[Jul 24, 2012, 8:45:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
svetl@n@
So it is impossible, the window remains to straight lines, it doesn't bend around a wall!!
[Jul 25, 2012, 12:03:13 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
oxygen
Russia
Hi)
As I understand you want to make something like this:
5 by pixie Xu, on Flickr
This picture without photoshopping so you can see that shelves was made with semi-circle primitives. So the idea is something like this - you build some walls (rounded or not) and than work with any-shaped primitives than apply to it the same texture as at the walls or make them wood-textured (for example).
And in Russian the same text wink
Привет) насколько я поняла, вам нужно построить полки в нише на полукруглой стене или просто нишу? Напрямую в программе это сделать нельзя, но можно найти обходные пути. Строим стену - округлую или скашиваем угол под будущую конструкцию. Дальше уже работаем примитивными фигурами - параллелепипеды, цилиндры, различные дуги, части шара и т.п., зависит от конкретной задачи. Строим конструкцию рядом со стеной, накладываем на нее нужные текстуры (как на окружающих стенах или наоборот что-то контрастное, например сочетание штукатурка/дерево). В моём примере как раз использован скошенный угол между стенами плюс полуцилиндры различной высоты. Если будет нужна вогнутая ниша - то этот самый сегмент можно будет сделать не выпуклым в сторону комнаты. а наоборот вогнутым, на нужных высотах и участках плана разместить параллелепипеды. Получится глубокая ниша полукругом. А там уже можно дальше играть "в кубики" laughing В общем, идея понятна?))
[Jul 28, 2012, 10:43:33 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
svetl@n@
ПРивет! Вы тоже из России?
спасибо большое, но задача немного другая!
как прикрепить фото в форуме, чтобы показать, что мне нужно?
[Jul 28, 2012, 12:16:28 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
oxygen
Russia
svetl@n@, да, из России)) Картинку прикрепляю не напрямую, а через сторонние хосты (я использую flicr, но сойдёт и радикал). Было бы неплохо увидеть, что вы имели в виду, тогда может помогу чем-то более конкретным. Дальше пишу дубль на английском, т.к. форум всё же не русский))
In English: if you can attach the picture, I hope that I can help you. For the attaching pictures you can use radical, flicr or something like that.
[Jul 28, 2012, 2:24:41 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
svetl@n@
это как через сторонние хосты?
[Aug 8, 2012, 2:44:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Please svetl@n@, write in English in the English parts of the forum, or I'll be obliged to remove your messages. The quality of your English isn't very important and you can use Google translate if needed. If you don't trust a translation tool, post your Russian messages in the Forum in other languages.
[Aug 8, 2012, 3:15:04 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
svetl@n@
Forgive that I do not observe a forum rule, I didn't know!
[Aug 9, 2012, 9:41:07 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
svetl@n@
Оxygen, подскажите, что означает: хосты? Что значит стороннние хосты?
English: Prompt that means: hosts? What means other hosts?
[Aug 9, 2012, 9:46:23 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
