Previous Thread This topic has been viewed 2464 times and has 2 replies Next Thread
Clovis
Rotate part os a projec
Is possible to rotate only a part of a project, includin some walls (their are not atached to the part that I dont want to rotate, I will atach after rotating)
Thanks
Clovis
[Jul 25, 2012, 10:13:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
macfrog
Germany
Re: Rotate part os a projec
Clovis,
it depends: do you mean furniture as well or just some walls and rooms?
In general, you could select all you need and copy it to the clipboad and paste this part to another empty project and rotate this part of the plan.
this can be used for walls and rooms.
hint: if you want to detach one wall from another, you just cut/paste the selected wall onto the very same spot (helpful for splitted wall segments).
the furniture has to be grouped together and rotate as on single object, later to be ungrouped of course.
macfrog
[Jul 26, 2012, 10:52:55 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Maybe you could try also to use the Advanced Editing plug-in described in this document.
[Jul 27, 2012, 6:38:25 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
