Posts: 21   Pages: 3   [ Previous Page | 1 2 3 | Next Page ]
Previous Thread This topic has been viewed 141943 times and has 20 replies Next Thread
Re: Textures Library Editor released
MarcoH, rotating textures can be performed only in Sweet Home 3D, not in the Textures Library Editor. From version 5.5, you can set any angle.
SnakeGB, I'll see if I can improve the naming system in a future version of the Furniture Library Editor.
Campi, the Jar executable files shouldn't be unzipped, run them with Jar Launcher. Note that I don't think that the Furniture Library Editor can run with Java 9 under macOS at the moment, and you should rather run it under Java 8.
[Nov 23, 2017, 12:22:17 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Campi
Thanks Puybaret
I've done some research since I posted and indeed el captain with java 9 has caused some problems with jars. For some reason 10.11 does not have the launcher from what i understand.
My next hurdle will be to to uninstall 9 (as it seams you can't install older versions over newer) since I'm not that proficient with the terminal haha
Thank you for the link since apple no longer supports legacy java
Thanks again
[Nov 23, 2017, 3:14:37 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Campi
OK that did the trick java 8 installed. The jars still show as zip files but at least I can open with terminal.
Thank you Puybaret!!
[Nov 23, 2017, 4:11:35 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Campi
Hi Again
I know I am missing something but just can't seem to get it to work.
I know this is a java/os problem but perhaps you might have some insight.
I got the texture and the furniture editors to open using the terminal but when I try to open a library I get nothing in the texture editor and the furniture editor crashes when opening a furniture lib.
I have tried all the versions of the editors and same thing happens.
I know this works because the furniture editor worked fine with 10.8
Again, any insight would be appreciated
[Nov 24, 2017, 5:05:09 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
What Java version is displayed in the About dialog (click on the light bulb at the end of the toolbar)?
[Nov 24, 2017, 5:51:06 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Campi
1.5 for the Texture Lib Java version 9.0.1
I have also tried 1.3 and 1.4 both indicate Java 9.0.1
[Nov 25, 2017, 4:13:44 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
FPatrick
Bonjour,
SH3D est toujours aussi plaisant à utiliser, Merci !
Je viens de mettre à jour Textures Library Editor avec la version 1.6. Mon système d'exploitation est Xubuntu, java version 11.0.6 est installé.
Je lance le soft sans problème, j'accède au menu « Ouvrir une bibliothèque de textures », je sélection une bibliothèque créée il y a deux ou trois ans (Ma_Bibliotheque_textures.sh3t)... et rien ne se passe.
Une idée ?
Merci par avance !
[Mar 31, 2020, 3:53:48 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
otadmin
Has there been a solution to the problem? I am on Jave 11.0.8, LinuxMint 20 and the same happens here - empty texture editor.
[Sep 5, 2020, 1:59:53 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
otadmin
Solved my problem by installing Texture Editor 1.6 from the Sweethome website. Version 1.6.2 in the repositories of LM20 not working.
[Sep 21, 2020, 6:37:08 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Soulbrother
A wish:
could you integrate the category in the Preferences, so that we can setup a category (new or existing).
OR
is there any other way, to avoid manual choosing and entering for each texture in one lib.?
[Jul 27, 2022, 1:40:12 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
