Total posts in this thread: 5
Previous Thread This topic has been viewed 8415 times and has 4 replies Next Thread
awiklendt
How can I select all walls (to change thickness)
Hello,
I have built my whole home and realised that I have my brick wall thickness (depth) incorrect (all internal walls are brick).
Can I select JUST the walls and change their thickness in one go? This is important because it is effecting the dimensions of various rooms and placement of various doors etc.
I have been able to select individual walls for modification, but was wondering if there was a simpler way.
Thanks.
A
[Oct 25, 2012, 9:03:17 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: How can I select all walls (to change thickness)
The simplest way is to click in the plan to bring focus into it, choose the Edit > Select all menu item, then select Plan > Modify walls. Nevertheless, if you already place doors and windows on walls, you will have to move them a little forward and backward so they adapt their depth to the new wall thickness.
[Oct 25, 2012, 9:26:45 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
And the fastest way is to use CTRL-A, then right-click and select Modify walls.
[Oct 25, 2012, 9:55:15 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
awiklendt
oh awesome, thanks for the quick and helpful reply, that sounds great :-) i knew there'd be a quicker way than i was using! and no worries about the windows and doors, there's less of them than the walls ;-)
[Oct 26, 2012, 11:04:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
eliezerhilario
Dominican Republic
Excelente. Muy útil. Muchas gracias
[Nov 13, 2022, 2:31:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
