Previous Thread This topic has been viewed 4911 times and has 2 replies Next Thread
malc_b
downlight light source?
Is there a downlighter light source around anywhere? I've sort of faked one up by putting a light source in a tube but the effect doesn't match what I expect to see.
TIA
[Nov 16, 2012, 7:56:05 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: downlight light source?
Using light sources should be enough, unless you want to display them turned off.
[Nov 18, 2012, 11:06:17 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
malc_b
I assume a light source model is a point source with equal intensity in all directions? Downlighters have a limited angle (MR16 bulbs are 36deg to the 50% points I think). So a 180deg source will not give the same effect. Is it easy to make a light source with varying intensity?
[Nov 19, 2012, 12:38:55 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
