Total posts in this thread: 8
Previous Thread This topic has been viewed 6210 times and has 7 replies Next Thread
Remoska
Graphic Card
what kind of graphic card would you recommend?
I have an old piece ... NVIDIA GeForce GT 220
I guess, that´s the point, why is the rendering of 3D so slow.
Any tips, whats the minimum to get an optimal run.
Thanks
[Nov 19, 2012, 6:21:21 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Graphic Card
What quality level do you use in the photo creation tool?
[Nov 19, 2012, 8:24:50 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Remoska
Re: Graphic Card
Always the best, sometime with light. The rendering of photos is slow, but workable. Rendering of videos with better resolution is impossible.
[Nov 20, 2012, 10:31:19 AM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Graphic Card
Keep your money then. The graphics card isn't used at the two best quality levels.
[Nov 20, 2012, 2:42:01 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Remoska
Re: Graphic Card
Thank´s, have you any idea, why is it then so slow?
[Nov 20, 2012, 3:34:24 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Graphic Card
Please read the FAQ How can I speed up the rendering process in photo and video creation panes?
[Nov 20, 2012, 4:14:10 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Remoska
Re: Graphic Card
Thank you very much.
"...install a 64 bits version of Java on your system, download the Jar executable version of Sweet Home 3D and execute the java -Xmx4096m -jar path\to\SweetHome3D-3.7.jar command for 4 GB... "
The first two steps are OK, the execution of the command should be done in the windows command line? (I did it, but not sure if something happend)
[Nov 21, 2012, 4:14:52 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
Re: Graphic Card
Yes, but you can launch it also with Run text field. Be sure to give the real path to SweetHome3D-3.7.jar (you can drag and drop the file in the command line window to reproduce its path).
[Nov 21, 2012, 4:30:19 PM] Show Printable Version of Post    View Member Profile    Send Private Message [Link] Report threatening or abusive post: please login first  Go to top
